drain back shw
ws9876
Solar Expert Posts: 440 ✭✭✭
For a drain back system to work the panel return port needs to be higher than the pipeline back to the hot water tank,no???
what would you do if a portion of the return line was higher than the lower panel port but not by much..??
Re: drain back shw
Read this guy's trials and tribulations...
http://www.arttec.net/Solar/BarnHeat.html
You will find out many of the common mistakes/problems with doing solar thermal systems. Very sharp guy and he documented his project well.
You would not believe there are so many ways of getting into trouble with a "simple" hot water system.
Re: drain back shw
that is frightening
I know I could do a simpler version
- 626 Discussion Forums/Café
