Planning my 750W Off-Grid System - Am I doing it right?
Re: Planning my 750W Off-Grid System - Am I doing it right?
blackcherry, if you are still following this, what is your charging profile like on the Sam's Duracell GC2's (FLA)? Anything special?
Caribocoot, BB, et. al., thanks again for your help. I will have a new schematic soon for y'all to pick apart. -
Re: Planning my 750W Off-Grid System - Am I doing it right?blackcherry, if you are still following this, what is your charging profile like on the Sam's Duracell GC2's (FLA)? Anything special?
Re: Planning my 750W Off-Grid System - Am I doing it right?Having bus bars also allowed me to put a small circuit breaker on the cable leading to the positive bus bar (poor man's version of the Blue Sea terminal fuse)---I'm hoping this will protect the wires against a short circuit of the batteries.
Even more important than protecting the wires from a short circuit is protecting the battery itself from a short circuit. Of course, it's not good to vaporize your wires, but it's even worse to explode your battery.
If you follow code, the batteries will be in a box and the battery cables will be in conduit to an electrical panel with appropriate OCP.
Damnit, the guy I get my Solarworld 275W panels from has slashed prices again. $1.14/watt delivered to me, I may end up with another one.
