axial flux generator question
Windy
Registered Users Posts: 18 ✭
www.alibaba.com/trade/search?fsb=y&IndexArea=product_en&CatId=&SearchText=axial+flux+permanent+magnet+generator
www.qm-magnets.com/product_Generator.htm
I know im asking many questions but thats how I learn and I rely on this forum.
If I would build my own turbine with an axial flux generator ( hugh piggot) style , what would you recommend?
Inner rotor or outer rotor? I read that inner rotor have more cooling.
And if you check those links they start from few inches up to 28 inches in diameter.
Whats more recommended for a turbine project?
Larger diameter with less rpm 100-150 or 150-300? Or medium size with more rpm?
Thank you in advance for all your good answers. God bless
Re: axial flux generator question
You might also try some other forums that are wind centric:
www.otherpower.com (good forum for DIY Wind Power)
Hugh Piggott - Scoraig Wind Electric site for tons of info (from mike90045)
Scoraig Wind "Recipe Book" for DYI Turbines (from Chris Olson... From his 4/11/2013 post)
www.greenpowertalk.org (added from "russ"--Like here but more wind/less solar)
We tend to have fewer folks here on the wind side of renewable power.
Re: axial flux generator questionYou might also try some other forums that are wind centric:
-Bill -
Just asking, is there a disadvantage if the core area of a generator is so small?
- 626 Discussion Forums/Café
