Mixing panels
unyalli
Solar Expert Posts: 121 ✭✭
After reading about this topic quite a bit I'd like to open this can of worms one more time. I have in my possession 4 Solartech SPM130P-S-N's I will mount on the roof of my RV and wire in series/parallel two sets of two. The specs are Vmp 18.1 and Imp 7.38 so two of them in series is Vmp 36.2. These will connect to my Midnight Classic 150. I also have two Solarland SLP90-12U's I will use as a portable array with Vmp 17.2 and Imp 5.23 so two in series is Vmp 34.4.
If I connect them all to the classic will the portable array cause too much loss in efficiency of the big array? or Should I connect the portable array to my also existing Sunsaver MPPT and attempt balancing the battery voltages and temp compensations? I have battery temp sensors for both controllers.
Jeff
Jeff
Re: Mixing panels
I wouldn't worry about it much. The Vmp difference between the strings is just a bit over 5%:
(36.2 - 34.4) = 1.8 * 100 / 34.4 = 5.2%
On the whole the panel Voltage will probably sag that much in the heat anyway. -
Re: Mixing panels
Thanks Coot.Cariboocoot wrote: »I wouldn't worry about it much. The Vmp difference between the strings is just a bit over 5%:
Jeff
- 621 Discussion Forums/Café
