Looking for water pump
Stdyhand
Solar Expert Posts: 33 ✭
I have a 1500 gallon water cistern, approximately 8 feet tall. It will be located right next to the house on the same side as the kitchen and bathroom. I am looking to install a water pump and would prefer to use a DC pump since I'll be using solar on site anway and I'll have the battery storage room near the water cistern/pump also.
At the most there will be maybe a shower running and a load of clothes being washed and probaly rarely will this even be at the same time. I don't foresee any more water than that being needed at any given time. All outside irrigation will come from greywater recycling or from a separate water cistern.
I am looking for a DC battery powered pump that can provide sufficient water flow but still use as little power as possible.
Re: Looking for water pump
check out offerings from boating, RV and camper shops for 12V domestic water pumps.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
