Solor Power 6 volt
Hi,
I have got a baby solor panel that gives around 2 volts of power ( Not much ), And I have just put it on a wooden board. I was thinking, What could I add to this thing so it puts out around 6 volts.
Thank You for your time
bye :-D
  • System2
    System2 Posts: 6,290 admin
    Re: Solor Power 6 volt
    Two more baby solar panels wired in series with the first.  Volts isn't power, volts X amps is power.
    Cheers,
    Bad Apple
    add about 8 more of the same kind of solar cells to it or buy 2 more of the little panels that you already have one of and place them all in series.
