differences between outback inverters
upa123
Registered Users Posts: 17 ✭
I have an opportunity to acquire a GFX3648 inverter under some very good terms. My application is completely off grid site. I understand the GFX series inverters have off grid, on grid and grid interactive capability. Is there any reason I should not get this GFX inverter vs a dedicated off grid VFX inverter ? I have read the online manuals and I just want to make sure I am not missing some major disadvantage. Thank you kindly for any advice.
Re: differences between outback inverters
I only know of one issue: it expects grid quality input on it's AC input when charging. In other words you'd need an inverter generator like the honda EU if you want to use a generator with it. Normal small gensets typically won't meet the narrow frequency or voltage requirements. -
Re: differences between outback invertersI only know of one issue: it expects grid quality input on it's AC input when charging. In other words you'd need an inverter generator like the honda EU if you want to use a generator with it. Normal small gensets typically won't meet the narrow frequency or voltage requirements.
Ah, perfect thank you. I already own an assortment of gennys including an EU, so I think this may work. -
One other thing. The manual states they can't be wired in parellel with an 240 (dam, can't think of the name) tingamagig that turns 120 volts to 240 volts. The G inverter is what I have and how you want to use it is how I am using it. It just means I will have only 7200 watts and one inverter won't sleep when using low 240 volt power. That will perhaps cause a few extra watts of loss.
Cheers
gww -
Can you use A PSX-240 with one GVFX3648? -
Re: differences between outback invertersCan you use A PSX-240 with one GVFX3648?
- 626 Discussion Forums/Café
