aleko /gudcraft
mahendra
Solar Expert Posts: 178 ✭✭✭
hi there has anyone had any experience with aleko or gudcraft wind turbines and their line of charge controllers?thanks in advance.
Re: aleko /gudcraft
Welcome to the "identify that chinese wind turbine manufacturer" game show! Where you can look forward to hours scouring through images of turbines to try and find the actual manufacturer
Aleko and gudcraft are resellers and to confuse matters they seem to use different manufacturers for different turbines. This aleko: http://www.alekogreenenergy.com/ALEKO-WG4500A-4-5KW-120V-Wind-Turbine-p/wg4.5kw.htm looks completely different to this one: http://www.alekogreenenergy.com/ALEKO-WG3000-Wind-Turbine-Generator-3000W-72V-p/wg3000w72v.htm
The first one looks similar to the Annui Hummer brand, the second one, I have no idea. The gen head and position looks similar to Exmork but the tail is different. -
Re: aleko /gudcraft
so in your opinion its no good correct?because look at the specs of the turbines the seem good and even the reviews.but looking at the charge controller the come with ,then it started to scare me thats why i asked for a second opinion. -
Re: aleko /gudcraft
I couldn't say either way. My point was that if you're looking for opinions on them, first you'll have to find out what make they are. Once you know the make, it'll be easier to search for opinions or user experiences.
- 626 Discussion Forums/Café
