Primus Air 40
DesertRat86438
Registered Users Posts: 1
Typically, what equipment is used with the Air 40? From a DC disconnect on the tower to a some kind of turbine control and dump load. The turbine puts out 48 VDC, can it be connected directly to a charge controller? Thanks.
Re: Primus Air 40
Sorry, have to go right now...
Have you taken a look at the manuals (our host, NAWS, has them online):
Primus Wind Power AIR 40 Specifications
Primus Wind Power AIR 40 User Manual
Re: Primus Air 40DesertRat86438 wrote: »Typically, what equipment is used with the Air 40? From a DC disconnect on the tower to a some kind of turbine control and dump load. The turbine puts out 48 VDC, can it be connected directly to a charge controller? Thanks.SMA SB 3000, old BP panels.
