MPPT charge controller recommendation
2»
    Re: MPPT charge controller recommendation
    there may be another cc soon to be available down the road from midnite solar called the kid. i hope halfcrazy doesn't mind my quoting him from midnite solar's website.
    "The timelines on the stuff is all over the place. But the 30 amp MPPT controller dubbed "The Kid" is real close. It is working and making power. Mario has the last rev of boards ordered and Robin will design the casting as soon as we have boards.
    The Inverters will be longer. not sure on the timeline? Maybe 2Q or 3Q of 2013.
    Ryan"
    i should ask you ryan just what battery ranges the kid will be able to charge at and what kind of upper voltage limit will be present on its input?
  • mahendra
    mahendra Solar Expert Posts: 181 ✭✭✭
    right neil i asked the same question and got the same answer from midnite solar
