The SunPlug Plug n’ Play Solar Kit
RSSfeed
Registered Users Posts: 3,810 ✭✭
GoGreenSolar.com is proud to present our original product, the SunPlug Plug n’ Play Solar Kit. This all-in-one unit is comprised of a 235 watt solar panel, a micro-inverter, and a racking frame that gives you the option of easily placing the SunPlug on the lawn, deck or anywhere else the sun shines, rather than being permanently installed on the roof. Simply place the kit in the sun (ideally facing South), plug into a standard 110 volt...
go to solarfeeds for the rest of this story>>>>>
More...
More...
Re: The SunPlug Plug n’ Play Solar Kit
The generic warnings--Yes, it will work. And depending on your loads and your utility meter, the meter may spin backwards, not move, or even charge you for the 'privilege" of generating your own power.
And there is the whole it may be illegal under your local building code, and most utilities will have the "right" to terminate electrical service to your home if you "go guerrilla" with GT solar. And, depending how it is all installed, can increase the risk of fire/electrocution/lightning or wind damage...
Re: The SunPlug Plug n’ Play Solar KitThe generic warnings--Yes, it will work. And depending on your loads and your utility meter, the meter may spin backwards, not move, or even charge you for the 'privilege" of generating your own power.
Yes, just like the standalone plug-in GTIs from China, this may be legal to sell, but not legal to use. I am appalled that this got the publication status that it did from a ?reputable? source. When Solar Feeds reprints lab result grandstanding, etc. it does not directly hurt anyone, but when they reprint verbatim an entry like this from the manufacturer's own blog they are condoning irresponsible use!SMA SB 3000, old BP panels. -
Doesn't anyone filter this stuff? Having this sort of thing in the mix of articles lowers the credibility of the feed, IMO. -
It is automatically (software) filtered...
I am of mixed opinion here... Let the post stand (until it gets deleted in a couple months--we don't archive RSS feeds), delete the thread in our forum--Or add a post about the issues and move on with life.
Obviously, I did the last and added a quick post on the problems with such a setup. The article is out there anyway--So having something that discusses the down sides of such an installation vs just ignoring it seem the better way to address the original article.
Re: The SunPlug Plug n’ Play Solar KitDoesn't anyone filter this stuff? Having this sort of thing in the mix of articles lowers the credibility of the feed, IMO.
In general, no. It's an automatic news feed from various sources. If we have to evaluate every one of these posts for accuracy we'd be unpaid full-time editors for dozens of news (and I use the term loosely) agencies. There are some filters set for the worst of it, and every time a known spammer sneaks through he gets deleted, but otherwise it's too impractical to vet every Rss post.
Caveat lector. -
Some obvious commercial RSS messages are deleted by the moderators, and from time to time all are purged that are older than 30-60 days or so. We dould turn the RSS feeds off, but enough useful info shows up that I would rather not do so.
- 626 Discussion Forums/Café
