Source for single 10awg stranded copper UV rated?
DSinOR
DSinOR Registered Users Posts: 18
Where can I buy single 10awg stranded UV rated for rooftop combining, sold by the foot? I only need 20' each of red and black.
Thx!
    Re: Source for single 10awg stranded copper UV rated?
    From some earlier posts on the forum--You probably will only find black UV rated wire--No other colors.
    The typical solution is to use rolls of colored tape to mark the last 6-12 inches of wire as it enters the box.
    or 'heat shrink' in red or other preferred colour
  • DSinOR
    Okay - any links to a source for black UV wire by the foot?
    Thx.
  • Vic
    Hi DS,
    Often MC Extension Cables are used .. buy about twice the length than you need, and cut it into two sections:
    http://www.solar-electric.com/incaforsoelp.html
    The Host of this Forum seems to NOT stock #10 AWG XLP, has the proper rating for direct exposure.
    FWIW, Vic
  • DSinOR
    Hey, that what I needed! "XLP".
    I found a couple places selling it for 50cents per foot.
    Here some in white http://www.solarpanelstore.com/solar-power.wire.tray_cable.pv_10awg_wht.info.1.html
    Thx!
  • ggunn
    FWIW, John Wiles recommends using only black PV wire even if other colors are available. He has data to support his opinion that UV eventually breaks down the other colored insulation.
    the use of colored tape or shrink tubing on the wire ends can be used to identify the +.
  • rollandelliott
    rollandelliott Solar Expert Posts: 834 ✭✭
    ontility.com
    ebay.com
    directpv.com
    lots of places.
