How do you connect a parallel battery bank to controller
TDSolarguy
Solar Expert Posts: 31 ✭✭
Hello All
I'm needing some advice on how to connect to a solar controller from two batteries connected in parallel . I know that on the battery side one connects positive to positive and negative to negative.
The step on where to connect from the batteries to the controller is what I'm not sure of.
Do I connect from one positive on one battery and then negative from the other battery to the controller?
Or do I connect one positive and one negative from just one of the batteries to the controller.
I'm thinking it's the first one.
T D Solar guy
T D Solar guy
Re: How do you connect a parallel battery bank to controller
Ideally, you want the resistance from the "bus bar +/- common points" to be equal path (resistance) to each battery in parallel (to ensure balanced current flow during charging and discharging). Here is one website that does a good job of explaining the options:
www.smartgauge.co.uk/batt_con.html
TD, that smartgauge site is a great resource, but it illustrates how to connect 4 batteries in parallel. Here is a more explicit diagram for 2 batteries.
Re: How do you connect a parallel battery bank to controllerTDSolarguy wrote: »Do I connect from one positive on one battery and then negative from the other battery to the controller?
You are correct: it's this one. -
Thak you so much guys.
T D Solar guy
- 626 Discussion Forums/Café
