Easy DOD Question
rene26
Registered Users Posts: 5 ✭
I've got what I think is an easy one for you here...
Most charts I see showing battery SOC and their related voltages show a 12V battery, at 50% SOC, having a voltage of 12.06V. A battery is considered to be completely discharged when the voltage reaches 10.5V.
Now, my manual for a Magnum 4448PAE inv/chrg tells me to set my low battery cut out--if I want to cycle down to 50%--to 10.0 to 11.4VDC (for 12V systems), or 40.0 to to 45.6VDC (for 48V systems). How in the world can this be? How can setting a low battery cut out at 10V represent a 50% DOD? It is below the commonly accepted value for a 0% SOC battery.
Is it because the batteries, under load, show a lower value than they actually are, and then when the load is removed they snap back to a higher voltage?
Thanks for your replies.
Re: Easy DOD Question
Hi Rene26, welcome to the form.
Good question
In reality, the low battery cutoff with inverters, is to protect the inverter, not so much the battery. How can that be? Well the lower the battery voltage goes, the greater the current the inverter must handle in order to maintain it's output power in watts. With a heavy load, there comes a point as the battery voltage lowers, when the current that must be drained from the battery in order to maintain the wattage demanded by the load, becomes higher than the inverter can handle without emitting smoke. Thus to save the inverter, it shuts down. Watts = Voltage X Amps. -
Batteries voltage under load is lowered and does not reflect SOC. It may take several hours of absoutly no load to reflect SOC. The best choices are a hydrometer to measue SP or a battery monitor to measue the actual power added/removed from the batteries.
An inverter can be a very heavy load that significantly lowers the voltage during operation. -
the guys pretty well nailed it as dod voltages and the inverse of the dod the soc voltages are at rest states of a battery voltage. under load it (the voltage) goes down and during charging it can go down, stay the same, or go up depending on the current being inputted vs the current being outputted (if there is a load on it). -
New poster "leaf" has a really nice set of charts that compare battery voltage against different rates of discharging and charging (as well as resting voltage readings).
I don't quite a agree with the resting voltage line (I think the voltage is a bit low)--But it shows how to estimate a battery's state of charge while operating.
Note, where the charts "flatten out"--the room for error estimating state of charge is pretty high.
- 626 Discussion Forums/Café
