CNC Machined 1000 Watt Wind Turbine
mroy0404
Registered Users Posts: 2
Here are afew pic's of the CNC machined wind turbine I have been working on this past spring. The prototype has worked so well, I made 4 more units!! The 4 newer units have been powder coated white and I used all 304 stainless steel fastners to hold them all together.
Tell me what you think of the design.
Here is a link to my photobucket page.
http://s41.photobucket.com/albums/e288/mroy0404/Wind%20Turbine/
Re: CNC Machined 1000 Watt Wind Turbine
well, it looks pretty, but does it work? details, specs, etc. -
Re: CNC Machined Wind Turbinewell, it looks pretty, but does it work? details, specs, etc.
We will be setting 1 of these units up this week sometime, I will keep you up dated with results. Here are afew more pretty pic's for you to look at for now. -
Re: CNC Machined 1000 Watt Wind Turbinewell, it looks pretty, but does it work? details, specs, etc.
That is some insanely nice machine work. Even if it never generates a single watt of output, that is definitely something to be proud off. I'm guessing that you have been machining for a while.
-Mark -
Blades look pretty much identical to the Hornet I had. It too was pretty to look at, but as for producing any usable power? That's a whole different story.
First quote: "The prototype has worked so well, I made 4 more units!!"
Then when asked: But does it work, details, specs etc, the following quote:
"We will be setting 1 of these units up this week sometime, I will keep you up dated with results."
Very interesting. It's listed as a 1000 watt turbine that works well, but hasn't yet been tested? -
- What is the diameter of the blades?
- Where did you get the blade design from?
- What material are the blades made of?
- How does the Wind Trubine protect itself from over-revving in high-winds?
- What wind speed is needed to generate the rated 1,000 Watts?
- How did you meaure the 1,000 watts of power?
- Did you read the Voltage and Amperage simultaneously?
- What type of load (batts or load bank) was used to measure the 1,000 watt output?
- What were the simultaneous Volt / Amp readings that computed to 1,000 watts?
- What gauge wire did you use to wind the alternator?
- Is this a 12 Volt, 24 Volt, 36 Volt, 48 Volt or other design?
- Is this a 3-Phase AC design?
- Are the rectifiers located inside the wind turbine or external?
- Did you use slip-rings?
Thank You,
- 628 Discussion Forums/Café
