TBS Omnicharge Inver/charger OC24-30
westbranch
Any one have any knowledge of/experience with the OC24-30 Omnicharge charger?
A Dutch product.
It is 24V 30A programmable charger, with a secondary charge output of 2.5A.
89% Efficient.
Input PF= 95%.
Continuous charge duty cycle.
max ~= 864W absorb, 810 W float, 930W EQ.
Programmable for all 3 types of common battery types plus a custom option.
Line Deleted :
Info at http://www.tbs-electronics.nl/downloads/OC20-60D-EN-REVA.pdf
TIA
  • stephendv
    Re: TBS Omnicharge Inver/charger OC24-30
    Interesting, never heard of it before.
    FYI, since you're looking at toys on this side of the atlantic, Victron also makes battery chargers:
    http://www.victronenergy.com/chargers/ with power factor correction.
    And fronius has some interesting options for traction batts:
    http://www.fronius.com/cps/rde/xchg/SID-70D248E8-7A9DE8EA/fronius_international/hs.xsl/17_525_ENG_HTML.htm
    doesn't seem too efficient in float mode.
    Appears to be because of max 30 amps and a lower V for float.
    BB. Super Moderators, Administrators Posts: 33,445 admin
    Quite a few pieces of equipment have better Power Factor at 100% load vs running at lower power levels (motors, non-PF corrected power supplies, etc.).
    It is a trade off between cost and the fact that, at lower power levels, "poor" power factor is not as big of issue (less power/current flow anyway at lower power levels).
    Stephendv, thanks, looked at the closest 24V Victron Phoenix model... it has a lower Amp (25A) output than the TBS OC 24-30.
    Don't have a need to go to the larger 3Kw model.
    Fronius is 220V model.
