Batteries and CC vs Series and Parallel
Scottg4001
Solar Expert Posts: 47 ✭
I am gathering new info everyday, so here is my next finding and question. I just found out that my AGM batteries can accept a certain maximum charge voltage or it will damage my batteries. The charge controller does regulate this voltage at 28.5 volts, which is perfect. If the battery charge is only requlated at 28.5 volts and I have a input voltage of 55 volts, is there any reason to even have a MPPT charge controller and is there any reason to have my two panels in series? If I can't boost the voltage for my batteries, whats the point? I am thinking of just going back to parallel, with a input of 28-29 volts and 14Amps with a standard PWM controller. Does this make sense or am I missing something?
-Scott
-Scott
Re: Batteries and CC vs Series and Parallel
I think I responded to this here: http://forum.solar-electric.com/showthread.php?p=115020#post1150204 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i
