Panels on the cheap
Gregmik
Registered Users Posts: 19 ✭
I have been buying panels, one a month for a few months, from Amazon. I have 7 so far. They are $150 per panel(50 Watts) with shipping. Anywhere I can get them cheaper? Should I save for a few months rather than buying them every month?
Thanks in advance,
Greg
Thanks in advance,
Greg
Re: Panels on the cheap
have you check cragslist? sometimes people have left over for their projects, so they sell them cheap good luck -
No never thought of that....thanks!
Greg -
What are your ultimate goals? Are you shooting for a 12 volt system, or larger? What are the specs of the panels that you've already purchased. I know you said 50 watters, which is roughly 17.8 Amps. Personally I think you'd be better off getting into a larger panel. Thus far, you already have 350 watts, and for less than what you've paid already, minus shipping, you'd have only two panels to lug up to the mount, or roof. -
Re: Panels on the cheapWhat are your ultimate goals? Are you shooting for a 12 volt system, or larger? What are the specs of the panels that you've already purchased. I know you said 50 watters, which is roughly 17.8 Amps. Personally I think you'd be better off getting into a larger panel. Thus far, you already have 350 watts, and for less than what you've paid already, minus shipping, you'd have only two panels to lug up to the mount, or roof.
I have not posted much lately, I got p*ssed off at the electric company here. I am off grid and am building my system slowly. I only have about $150 a month to spare. I get my bats for free as I have a friend that repairs wheel chairs and Medicare and Medicaid allows them to replace the bats once a yr no questions asked. So I get yr old 74ah GC for free.
I have a gravity fed water system and most things run on propane. I have a generator that I use too much right now to charge the battery banks I have. I want to get to the point where I can run a fridge. Not there yet, but getting close. I am looking for a place where I can spend the money more efficiently.
Do a search for epcom 50W on amazon and you will see what I have been buying. I am a carpenter so mounting and installation is not a problem.
Greg
P.S. The more panels I get the more extra cash I get every month... -
Greg I think you will find if you search around a bIt that larger excellent panels can be had for about half of your $3 watt you have been paying. A while back there was a vendor with Evergreen panels for $0.78 a watt plus shipping. -
Re: Panels on the cheapI have a gravity fed water system and most things run on propane. I have a generator that I use too much right now to charge the battery banks I have. I want to get to the point where I can run a fridge. Not there yet, but getting close. I am looking for a place where I can spend the money more efficiently.
I can relate to the electric co. senario, and yes you do have a deal on the batteries. What type of inverter have you considered at this point? Also, is the fridge....supposedly one of those energy savers? There are plenty of people here on the forum already doing what you want to do. I also hope to run my fridge from my batts/inverter. In the meanwhile, I have a kill-o-watt meter attached in hopes that it will guide me to some justifiable point as to what exactly I do need. I presently have a 2k watt inverter. I know this is enough, but do I have the batt capacity, and solar charging to achieve it? At this point.....I don't know.,...........YET! However, I did research the panels you are getting/buying, yes a watt is a watt, and a amp is a amp........beware Greg, beware! A five year warranty off the bat does'nt get it.
Myself, I researched for 4 years before I made the plunge, and 11 years later........I'm still researching/questioning. Mabey, just mahaps, I'll know what the hell I'm doing before I'm 70. Always keep in mind....."you get, what you pay for." SOMETIMES! Enough said. Above all else, good luck with your project, and please keep the forum posted. -
Beware of getting in-compatible panels when buying piecemeal. Last years 19V panels will de-rate this years 26V panels.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Greg,
I know you are "p*ssed off" at the power company,, but at least you should be aware of this pesky fact. Grid tie solar comes at about have the price and twice the performance of battery based PV. It is important (for most) to realize that the grid is their best friend, even if the gate way (the power company) isn't. As a way to "get retribution" back to the power company, what better revenge would there be than to use their resource (the grid) and have them pay you to do so?
So often we hear from folks who for what ever reason, want to chuck the power company and go off grid. Once they are confronted with the reality of both off grid power limitations, as well as the huge benefit of the grid,, they often re think their plans. Just sayin' as they say.
Tony -
We always like to suggest Northern Arizona Wind and Sun, our sponser.
Someone use to advertise a book(let) on Ebay about how to aquire free or cheap solar panels. As I recall it was largely removing from building where they were installed in the early '80's and checking auto grave yards for solar signs that had been hit.
There are some reputable sellers on Ebay selling some panel w/o UL listing, I'll PM you a seller who I have some knowledge about. Ebay listings go up and down so I won't post here.
Likely you'll want to get just one more of the 50 watt panels so you can run in series to charge a 24 volt or 48 volt systems as your system grows. FWIW I didn't see anything about UL/TUV listing on your Epcon panels.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Price out Wind Sun's panels, dollars per watt, then compare to the panels you are buying @ $3/watt.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
- 299 In the Weeds--Member's Choice
