Combining differing Series Arrays
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I have 4 Mitsubishi 120W panels 17.6V Vmp, 22.0V Voc, 6.84A Imp, 7.36A Isc ...
I located some Luxen 130W panels 17.6V Vmp, 21.6V Voc, 7.39A Imp, 8.69A Isc
I plan on 4 series panels per array with 3 arrays in parallel, 12 panels per CC, 2CC's.
so there would be 1 array of Mits. and 2 of Luxen's on one of the CC's.
The Mits. Array = 70.4V Vmp, 88.0V Voc, 6.84A Imp, 7.36A Isc
the Luxen array = 70.4V Vmp, 86.4V Voc, 7.39A Imp, 8.69A Isc....no problems here so far, each array is 4 in series and they are all matched panels
But what happens when the array outputs are combined? the Vmp's match but the Imp does not?
Will the lower Imp be what the CC 'sees'?
Should I reassign the 4 Mitsubishi panels to another job?
Re: Combining differing Series Arrays
No worries. The Imp only matters in the series connection, just as the Vmp only matters in the parallel one.
So four of the Mitsu's in one string and four of the Luxen's in another one or two will be fine. The Imp's aren't that far apart here either. If it was a really big difference, fuses would prevent the higher current panels from frying the lower ones if something should go wrong.
