Interfacing with many Xantrex GT Inverters using RS232
Java_user
Registered Users Posts: 2
Hello,
I am new using Xantrex Inverter and I have some questions:
1- If it is possible using the RS232 port of the GT Inverter to use Modbus or it only admits ASCII Commands.
2- It is Xanbus the same that Modbus over CAN? If this is true, can I use the modbus memory map of the GT Inverter? And what is the addressing in this case?
3- Can I use the RS232 to communicate with many inverters taht are connected one another using xanbus? What RS232 ASCCI commands I need to use in that case?
Thank you very much.
Re: Interfacing with many Xantrex GT Inverters using RS232Hello,
1) Plain Ascii only
2) Its CAN physically, Xanbus protocol is based on NMEA2000
3) No
This is free monitoring software, nothing more can be queried from a Xantrex GT that this software does
http://www.solar-guppy.com/download/sg_view_151.zip -
And, how can the SG-View or the GT-view give the system total energy of many GT Inverters joined by xanbus? Are there RS232 ASCII commands for that?
Thank you.
