any one post there results to PVOutput.org?
jkhawaii
Solar Expert Posts: 30 ✭
I've been posting my system output on PVOutput.org since monday. today with my single 130W Kyocera, 600wh's were produced, only 190 on monday because it was rainy and cloudy
Re: any one post there results to PVOutput.org?
so much for efficiency loss of a older panel! I seen 130 watts output, mid day, for the short wile the clouds cleared. Sunday is the only time I can actually monitor output, as I have to physically be there to monitor output haha. even when its cool and cloudy out I'm still getting at lest 25w. -
Yea, edge of cloud events can give you some surprisingly good power numbers.
Note that many charge controllers seem to estimate the output current by 5-10% high (nobody is ever unhappy if their solar system seems to output more than rated power:roll:).
And no system generates a lot of power in bad weather (or if partially shaded).
Other than the 130w spike, 100-110w seems to be peak output so far. -
I just uploaded my 3KW system data. Spent the day massaging the log files to get them into their format.
at http://pvoutput.org/list.jsp?userid=7947 & www.LuckyMonkeyRanch.com Northern Calif, south facing array @ 50deg.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
