Sizing A Generator
Mangas
Solar Expert Posts: 547 ✭✭✭✭
In case others missed the Home Power article by Jim Goodnight "Sizing a Generator for your RE System", I thought it was very well done.
Good to see they featured the Cummins Onan on upper end applications. Having owned one about a year, I agree.
Re: Sizing A Generator
Jim/Crewzer used to be a moderator here too (before me).
"Home Page" of article
Here is a PDF of the article (don't know how long it will stay up)
Thanks Bill, I didn't have the link. I do remember Jim before he left Outback for Schneider now I believe.
You guys sure have given me a good technical education the past 6 years. Better understanding for sure.
Well done.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers
- 626 Discussion Forums/Café
