Use car battery for lighting
theuns
Registered Users Posts: 7 ✭
HI
I would like to hookup up a 9watt, 230volt light to my 12V car battery, with a 12V 150watt DC to AC inverter.
The battery is not huge the car is a 1.6l opel, i have no idea about the amps hours.
Now i know that there is a huge difference between a car and deep cycle battery.
1. Will this work?
2. For how long will i be able use the light?
3. What will happen to the battery, in the long term?
Any answer will be appreciated, thank you.
1. Will this work?
Re: Use car battery for lighting
Please seems reply here:
http://www.windsun.com/Batteries/Battery_FAQ.htm#Lifespan%20of%20Batteries
Tony -
The inverter you are looking at, is likely a cheaply made "hunk-of-junk". They sell them by the thousands here in the USA. While they generally work, the self-consumption of the inverter will be more than the 9 watts the bulb consumes. I'd guess 20W just to power up the inverter, and then 9 watts consumed by the light. So you would be pulling about 30watts off the battery (2.5A)
A small car might have an 60 ah battery, and for occasional use (once a month) you can maybe consume about a fifth of that (20%) before you would have trouble starting the car and needing a jump. So I think 12A is 20% of 60, and that comes out to about 4.8 hours of light. Or maybe I made a mistake before my AM coffee, and someone else will set your right.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I use a Wallmart 12v trolling motor battery ( deep cycle), a 250w Cobra 12v inverter, and 35w solar panel to light my barn with a 150 watt halogen and a small cfl. The lights are only used for 15-20 min per day 2-3 times per week, no problems for the last 3 yrs. When not in use I turn the switch off on the inverter. -
As an example for the math (you can fill in your own numbers:
Assume:- 85% efficient inverter
- 6 watts of losses (minimum power to turn on inverter)
- use 15% of battery of available battery capacity (recommended car battery "deep cycle")
- 60 Amp*Hour battery capacity (smaller car battery)
- 12 volt system
- 60 AH battery * 12 volt * 0.15 of capacity / (6 watt inverter tare + (9 watt load * 1/0.85 inverter eff)) = 6.5 hours
Of course, if you have more accurate information, you can plug in your own numbers.
Also, for small loads, notice how much the inverter "costs" you for power:- 6 watts tare + 9watts*1/0.85 inverter eff = 16.6 watts
If you need general lighting, a 12 VDC florescent lamp might be better (LED's tend to be a bit more focused light).
It might be more difficult for you to find a good assortment of LED/CFL lighting--but if you can search boating and camping vehicle stores, you might find something there (probably not cheap).
Note that good LED lamps need a lot of heat sinking. The "cheap" bunch of LEDs soldered to a circuit board may only last 50-100 hours before they "turn black" from overheating.
- 626 Discussion Forums/Café
