SOLAR Laminate
conntaxman
Solar Expert Posts: 125 ✭✭✭✭✭
Has any one used these Laminate panels yet? Some places you can buy them very cheap but you have to connect the wires and connection box to the back of the panel. here are the spec.and price, most you have to buy 10 panels a time.
SUN Laminate 245 (Poly
Unit Price/Watts: $ 0.58
Pallet Price/Watts: $ 0.48
Container Price/Watt: -
Megawatt Price/Watt: -
Model Sun-P-245
Power (W) 245 Watts
Open Circuit Voltage (V) 30.00 Voc
Short Circuit Current (A) 8.37 Isc
Maximum Power Voltage (V) 23.70 Vmp
Maximum Power Current (A) 7.60 Imp
Number of Cells 48 Cells
Cell Type Poly-Crystalline
Frame Type: No Frame
Junction Box: No
Maximum Voltage System 1000V DC
Length 51.89" ( 1,318.01 ) mm
Width 39.13" ( 993.90 ) mm
Weight 41.89 lb ( 19.00 ) Kg
Certifications None
Warranty 20 Years
Model Sun-P-245
Power (W) 245 Watts
Junction Box: No
Certifications None
Warranty 20 Years
Re: SOLAR Laminate
These panels are not certified, so would be illegal for grid-tie installation. They will deliver the numbers published, but you incur additional expenses (MPPT controller) in order to direct their full output power. With a Vmp of 23.7, these 24Volt panels are unable to charge a 24V battery bank. The more expensive type of MPPT controller must be used to either down-convert, or regulate a series of panels to the charging voltage you need.
