Solar Shingles <again>
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
Watch out, here they come again.... By DOW
The POWERHOUSE (TM) Solar Shingle is Made in the USA at Dow's small-scale manufacturing facility in Midland Michigan. Dow has also begun construction of a new, large-scale facility at Dow's Midland, Michigan Operations site, which the Company expects will create up to 1,275 jobs between now and 2015.
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Solar Shingles <again>
So how much did the DOE dump into this one :roll: -
With a little selective lobbying, I'm sure DOW is way ahead.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
