solar in Iraq
t00ls
t00ls Solar Expert Posts: 245 ✭✭✭
Just thought I would share some photos with all of you...solar lighting all over in bagdad
    Re: solar in Iraq
    Interesting... I wonder if it will all still be working in 5-10 years.
  • TheBackRoads
    TheBackRoads Solar Expert Posts: 274 ✭✭
    Re: solar in Iraq
    Are you there now?
  • t00ls
    Re: solar in Iraq
    yup.....just took these the other day
    part of the 149th out of kentucky.....closing down bagdad operations
  • Sparkletron
    Sparkletron Solar Expert Posts: 71 ✭✭✭✭
    Re: solar in Iraq
    Very cool. I'm guessing each panel makes power for its associated street light below? With maybe a battery inside the base of each tower? This kind of redundancy goes a long way in an area with frequent power outages.
    Re: solar in Iraq
    so who paid for those street lights i wonder?:grr
    i made the suggestion to a rep in the doe many years ago to do this here in the states due to power outages making roads unsafe and it would've taken the load off of the grid that is often strained too.
  • bmet
    bmet Solar Expert Posts: 630 ✭✭
    Re: solar in Iraq
    Please be careful of what you post publicly. Your schedule is highly sensitive information.
    t00ls wrote: »
  • techntrek
    Re: solar in Iraq
    We have these in several areas around my office. They were installed on the entire parking lot of the maintenance building, then in several areas around the main office building's parking lot to fill in where they needed more light. The more recent additions are doing fine, I've never seen them out. The ones on the other parking lot often require them to bring in several mobile light/genset trailers in the middle of winter for a month or two!
    They have several compromises to make them operate close to standard lighting (but still not the same). One, they mount the light fixture twice as close to the ground. Second, they have two lights in the fixture which alternate operation each night to double the maintenance-free run time. Both reasons are due to using CFLs which have less lumens to begin with and then loose brightness over time.
  • t00ls
    Re: solar in Iraq
    bmet wrote: »
    dont worry...Ive been in for 22 years........it's no secret that I'm with the 149th, and no secret that we are closing down operations here.......what is secret is the timeline and what exactly I do
    so........no sensitive info here
