What cable to use between panels and disconnect
Mike16W
Registered Users Posts: 9 ✭
I am installing my first PV system on my house and I will need to run 4 cables (10ga.), 120/240 single phase, between my junction box on the roof to the disconnect on the side of the house. I will need to run these cables 100ft though a conduit. Does anyone have a recommendation on what cable to use and where to get it for the best price. I understand I will need to use 10 AWG RHW-2 cable. Is this available on line and it would be great if each strand was color coded.
Thanks for any help.
Re: What cable to use between panels and disconnectI am installing my first PV system on my house and I will need to run 4 cables (10ga.), 120/240 single phase, between my junction box on the roof to the disconnect on the side of the house. I will need to run these cables 100ft though a conduit. Does anyone have a recommendation on what cable to use and where to get it for the best price. I understand I will need to use 10 AWG RHW-2 cable. Is this available on line and it would be great if each strand was color coded.
I'm pretty sure you can use THWN-2 for that run. -
Mike,
The host of this site carries several appropriate cables for PV wiring, exposed to the elements. One it Tray Cable, this one is 10 GA two conductor:
http://www.solar-electric.com/10-2-tc.html
Personally, have never used TC for this application, and prefer individual conductor, such as these:
http://www.solar-electric.com/incaforsoelp.html
I am ASUMING that you are in need of PV DC wiring from the panels to the combiner. Altho, the reference to 120/240 AC may change the above.
If there are junciton boxes on the panels, then you could run conduit from the panels to the combiner, and use Building Wire, THWN/THWN-2 (IIRC). Most building wire has this rating as well as THHN etc.
If you could be more specific about your need, it would allow better replies to your question.
VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
I am ASUMING that you are in need of PV DC wiring from the panels to the combiner. Altho, the reference to 120/240 AC may change the above. -
Yes, I will be using Emphase Micro-Inverters. Sorry, I should of stated that in my post. -
Re: What cable to use between panels and disconnectYes, I will be using Emphase Micro-Inverters. Sorry, I should of stated that in my post.
Thanks for the information about the wire needed. I checked and I need a disconnect next to my meter in order to meet code in New Mexico. -
Re: What cable to use between panels and disconnectThanks for the information about the wire needed. I checked and I need a disconnect next to my meter in order to meet code in New Mexico.
Um, yes, of course you do. Visible, accessible, and lockable. I don't know what I was thinking when I said that I didn't think you needed one. My bad. -
Thanks. I will use the THWN-2 wire you suggested. I imagine getting them in the different colors makes it easier to sort out and connect. Do you get your wires locally or on the web? Always looking for a good price. -
Re: What cable to use between panels and disconnectThanks. I will use the THWN-2 wire you suggested. I imagine getting them in the different colors makes it easier to sort out and connect. Do you get your wires locally or on the web? Always looking for a good price.
You could have both hot wires the same color, though, if your AHJ doesn't specify. It doesn't matter which one is which from the inverters. Make sure you figure the ampacity and temperature deratings and don't use wire that is too small.
It's not likely you'll find a significantly better price than at a local electrical supply house for such a small quantity of wire, and they will often sell you just what you'll need instead of a full spool.
- 626 Discussion Forums/Café
