Will 8 235W Day4 Out Performe 10 240W Sharp F1 Panels?
Trickle Charge
Solar Expert Posts: 28 ✭
Hi,
I realize the Day4 panels give a total of 1.88 kW but is there construction of 9 individual areas likely to give a better overall wattage when there's some shading or cloudiness over the Sharp. I can't find any info on the construction of the Sharp in that regard but here are two docs comparing both the Day4 and the Sharp with similar output ratings:
Day4 60MC
Sharp F1
Day4 60MC
Sharp F1
Re: Will 8 235W Day4 Out Performe 10 240W Sharp F1 Panels?
The two panels seem pretty similar... The Sharp have a 50 lb per sqft snow loading vs 30 psf rating for the Day4 panels--if that matters in your region.
Day4 panels appear to be sorted to meet various wattage outputs (around +/- 2%)... The Sharp have a wider tolerance range of +10/-5%... I would not pay extra for the sorting.
Have not heard about any problems with Sharp... Don't know anything about Day4.
- 626 Discussion Forums/Café
