battery voltage after charging?
klrskies
Solar Expert Posts: 30 ✭
After charging my sealed marine battery, and letting it rest for 6 hours, it indicates a bit over 13 volts. (13.05v). I had expected it to disapate any surface charge, an be around 12.7~12.8v. Why would this battery be at this voltage?
regards,
Ken
regards,
Ken
Re: battery voltage after charging?
There's a couple of possibilities here. One would be that Voltmeters are not certified by any regulatory agency to be precise in their measurements and may actually be off a few tenths of a Volt. Another (more likely) is that some companies sell "hot" batteries which have slightly higher SG and will produce slightly higher Voltage and current - and will drop dead slightly sooner than others. I can well imagine that some RV/Marine batteries are done up like this. Two tenths of a Volt I'd ignore; you can get that much variance with a Voltmeter on the same battery checked twice in a row.
- 626 Discussion Forums/Café
