DIscharge voltage level?
klrskies
Solar Expert Posts: 30 ✭
I've been stopping the discharge from my battery when the battery voltage equals 12.1v, but that's under a load. Is that how to gauge the cut off voltage, or is it the batteries' voltage level after the load is removed, and the battery has stabalized for a while that is used to determine discharge cut off?
regards,
Ken
regards,
Ken
Re: DIscharge voltage level?
Standard disclaimer: Voltage is not an accurate indicator of SOC.
That said, it would be a bit impractical to disconnect loads, wait a couple of hours, then check resting Voltage to see where it's at or dip the hydrometer in for a SG reading.
Your 12.1 Volts under load is as good an arbitrary cut-off point as any, and ought to ensure you don't over discharge your battery. Remember that different loads drawing different Amps will bring the Voltage down different amounts; don't be surprised to see the V spring back up when a heavy load is turned off at 12.1. Of course a more powerful battery will withstand the drag of heavier loads better (less V drop).
For a very accurate on-the-go SOC reading you need a battery monitor. -
Thanks for the response. I've been looking at battery monitors, and they seem like the the ideal way to keep up with battery status...the tri-metric 2025 looks like a good one to consider...around $150 + a shunt. Beats having meters all over bthe place like I have now. -
The Trimetric is a great meter. It I'll give you pretty accurate gauge of SoC.
