Wiring diagram
spanel
Solar Expert Posts: 36 ✭✭
Does anyone have a link to a wiring diagram or similar that might include the following:
Solar panels
charge controller
batteries
generator
inverter
transfer switch
system monitor w/shunt
1 12v circuit for a water pump
Thanks!
Chris
Solar panels
charge controller
batteries
generator
inverter
transfer switch
Thanks!
Chris
Re: Wiring diagram
Outback has quite a few sample wiring diagrams:
http://www.outbackpower.com/resources/documents/wiring_diagrams/
Re: Wiring diagramDoes anyone have a link to a wiring diagram or similar that might include the following:
Solar panels
charge controller
batteries
generator
inverter
transfer switch
Thanks!
Chris
Sounds pretty Custom to me. I think you are going to have to get into more detail on your goals and the specs for the system parts.
I did a Google on 'Solar wiring diagram' and came up with a lot of different
diagrams that were just 'parts' of the total system, (per your list).
One item that you need to spec up front, is this off-grid, back-up or grid-tied? -
Re: Wiring diagram
I installed a similar set up at my family's cabin. There are a few differences, but it may get you started in the right direction. I would not use my diagrams as is, but compare them to other diagrams and understand why each diagram is different (why use a GFP or bus bars, etc...).
Cabin Power System Schematic
DC wiring diagram
The main differnce is that I'm running 12V LED lights instead of a 12V pump. Also, I haven't wired in a battery monitor yet (that's a summer project). Pending the size of your system I'm sure someone can come up with an elegant way to convert higher voltage battery banks to 12V. -
Re: Wiring diagram
here is one that will get you real close just missing the dc load breaker and monitor on the shunt
http://www.midnitesolar.com/pdfs/e-panelWIRE1revF.pdf
- 626 Discussion Forums/Café
