6KW Sys--->going for it (questions)
Gitchee Gumee Kid
Registered Users Posts: 19 ✭
Gentlemen,
I am about to close on a grid tied /battery back up(48v
four 12v /200ah) System
30 Kyocera (KD215GX-LPU)
> pole mount (two large dia pipe in concrete)
Schneider Electric (Xantrex) XW4548 Hybrid unit
My questions: will the XW 4548 handle what the installer has chosen?
Stringing options.?
15 modules/ pole ---->doable?
I've been reading this site for days ----you folks are awesome ( and so patient with us newbies)
Thank you.kindly.
GGK
>(location---> N Western Wisconsin )
Stringing options.?
Thank you.kindly.
GGK
Re: 6KW Sys--->going for it (questions)
Don't spend any money just yet...
Generally, the recommendation for a 4.5 kW XW inverter would be minimum of 450 AH @ 48 Volt battery bank. A 200 AH battery bank sounds quite small if you are planning on supporting 9kW surge current.
And too small a battery bank can be an issue with a large array--The battery bank voltage can surge and over voltage the DC input to the inverter...
Also, a 6.45 kW array with a 4.5 kW GT inverter? Why? Why not the XW6048 (it is not very much more money--and would recommend a minimum of 600 AH @ 48 volt battery bank for 12 kW surge support).
Regarding the pole mount--fixed not tracking? Do you have a structural/Civil Engineer ready to sign off? Do you have high/gusty winds in your area?
What Brand/Model of MPPT charge controller(s) are you planning on using between the array and the battery bank?
Backup generator planned? 120/240 VAC split phase (not 120 VAC only)?
- 626 Discussion Forums/Café
