How to add wind with enphase system
gtxkid
Solar Expert Posts: 34 ✭✭
What would be a good way to add a small wind generator with an enphase system.
Would like to do it the same way i did enphase install.
Is there anything out there i can use.
Was nice to wire up to a 220 amp breaker, simple and easy for me to do.
I have pole already installed.
Re: How to add wind with enphase system
You need to figure out how to get electricity from the Wind Turbine to your house mains (should be legally).
Your options:- Get a Skystream with integrated Grid Tied Inverter
- Get a GT inverter designed for wind
- Windy Boy (SMA)
- SWEA (makes un UL/NRTL Listed Wind GT inverters)
- Get a Hybrid Inverter
- Schneider XW Hybrid System
- You charge a 24 or 48 volt battery bank
- A 4-6kW Hybrid GT / Off Grid capable inverter takes the power from the battery and ships it to your utility lines
Don't spend any money at all--Until you have figured out the basics and checked references.
I am not a fan of small wind--I feel there is not much out there that will make you happy.
My two cents.
THis give's me something to think about. -
Tlg is now making a grid tied windmill, I have no first hand experience with the unit, however I have heard good reports about their smaller turbine.
- 626 Discussion Forums/Café
