Recharge Power Pack HF 96157
How large of a solar plane would I need to recharge a (12v/18Ah) Harbor Freight Power Pack 96157, over a one or two day period? it comes with a 12v adapter for charging.
Re: Recharge Power Pack HF 96157
Approximately 15-20 Watts should be sufficient with good insolation and no loads drawing while charging. Does it give an Amperage draw for the 12V adapter? (I presume it's meant to plug in to a car so you can take your power with you when you go camping.) Does it have internal charge regulating?
Personally I avoid HF equipment. :roll:
- 626 Discussion Forums/Café
