Best Grid-tied inverter for 180 KW DC System, 277/480Y Main Panel!!!
Batikikik
Solar Expert Posts: 141 ✭✭✭✭✭
Hello guys,
Which inverter(or inverters combination) will be the best for 180kw system with 277/480Y Service ???
String voltage - 526V
String Amp- 5.25 A
main Panel - 4000 Amps
Thank you
String Amp- 5.25 A
Thank you
Re: Best Grid-tied inverter for 180 KW DC System, 277/480Y Main Panel!!!Hello guys,
String Amp- 5.25 A
Thank you
Your voltage is a bit high but a pair of these perhaps if you adjust your strings
http://pvpowered.com/commercial/products/pvp100kW/ -
Yes I already did design with PVP100KW and PVP50KW .
But it will be better to install one inverter which is I am looking for
- 628 Discussion Forums/Café
