EcoDog vs Arduino
mr.radon
Solar Expert Posts: 158 ✭✭✭✭✭
Anyone here ever hear of or use EcoDog’s FIDO Home Energy Monitoring System?
Been playing around with an Arduino 1280 and a bunch of CT's. Coding is not my strong suit. Its reporting but now I have a bunch of data and nothing to crunch it with other then excel.
The EcoDog seemed to have a nice interface, and has 16 channels + is expandable, my Arduino experiment has 16 channels at 10 bit resolution (1023). I only hooked up (6) CT's so far.
Would love to hear from other users.
Re: EcoDog vs Arduino
I've been looking into Brultech ECM-1240. Have you looked into that one?
Got any details on how you're building your Arduino? -
Arduino, been monitoring the openenergymonitor site. Got some code from them. However, at best I can get one reading per second on the six channels. but I cant measure voltage and I haven't figured out how to automate the data transfer. I have to go in and manually download it.
hers is one of the sites: http://openenergymonitor.org/emon/node/58
Been doing it in my spare time. however, the EcoDog seems to have a good interface, kinda $$$ though. I guess its the geek factor. -
OK, I've looked into that Arduino project before. Just haven't had time to mess with it.
The Brultech starts at about $200 - more if you want automatic data logging and ethernet or wireless capability will double the price. But seems to be a better value than things like the TED if you want to monitor multiple circuits. And if you have a computer to do the logging via serial it's a pretty good price.
I've also looked at EcoDog - but can't find pricing. How much does it cost? -
You could upload data directly from arduino to the internet (pachube.com) using either an ethernet shield, or a computer connected to the arduino with USB, code available here:
http://community.pachube.com/arduino
I tried doing this with my arduino based SG monitor but had some issues with the ethernet module, it would work for about 15 minutes and then start behaving really strangely. Think it's an overflow in another part of my code because I know of users who are using the pachube code as is and it's working fine for them. -
Thanks for the advice. Will try that.
In the mean time I got a EcoDog demo unit heading my way. Will document the setup and usefulness. Software seems straightforward. -
What's the retail price on the EcoDog? -
Well i got the demo box and installed the 16 CT's. Took about 15 minutes. I had already over the winter break, located all the components hooked up in my house to each circuit breaker. This really helps when I want to work on something. It also helped me figure out which 16 lines I wanted to monitor.
The software is pretty easy to use. Will take and post a few screen shots. The system is scalable, you can add 16CT to a max of 1024.
They forgot to ship the board, I get that Monday, so I can't get any readings just yet.
I'll get the cost data Monday... I think retail it is $1,150. But I'm not sure. It is pricey for what you get. I'm figuring the CT's run about $10 and piece, so they mkae a pretty good profit. The nice part about this is the software. That was the hard part of the arduino board. (that and I was having problems measuring voltage) I needed the voltage to calculate power... -
Yeah, that's at least twice as expensive as the top-of-the-line Brultech hardware with similar capabilities.
But the software probably won't be quite as good. That said - you can write your own custom software for the Brultech hardware... -
I just got a price quote this morning, a bit over $900 for a system with 16 CTs.
Yup, I'm going with the Brultech 1240 -
I was wondering what the price of the Arduino was, and where the CTs were purchased from. To me, the Brultech prices seem a bit high, and their shipping charges are extremely high.
I'm also wondering why the calculations are being done on the Arduino, and if anything could be set up to just get the values from the CTs to a full-size computer that has far more computing power. -
Re: EcoDog vs Arduinosub3marathonman wrote: »I was wondering what the price of the Arduino was, and where the CTs were purchased from. To me, the Brultech prices seem a bit high, and their shipping charges are extremely high.
I'm guessing that you haven't tried actually pricing any of this stuff yet.
Before I came across the Brultech system I bought a couple CTs off ebay. I paid $8 each for them plus another $6 shipping (ea)
Brultech only charges $5 for their 40 amp CTs, a bit more for the 80 amp ones.
For less than $180 you can get the Brultech computer, 2 100 amp split CTs (look up pricing for them), 2x 80 amp and 10x 40 amp CTs.
If you were going to duplicate this setup with an Arduino you'd probably end up spending more (even if you buy the CTs from Brultech), and THEN you'd have to write the custom software to calculate power factor, etc. from the voltage and current measurements.
Plus you'd probably need several Arduinos, or add a couple extra analog to digital converters to match the 8 inputs from the Brultech (7 inputs for CTs and one to measure voltage). I'm not sure but I think the Brultech has higher resolution on it's A-to-D converters.
There might be something available that is cheaper than the Brultech, but everything I've found is either more expensive, less capable, or both.
Look into "The Energy Detective" less capability and higher price, or the EcoDog WAY higher price.
You might be able to do better with an Arduino if you're really good at programming. Just trying to figure out the coding for calculating power factor was more than I wanted to try. -
Re: EcoDog vs ArduinoI'm guessing that you haven't tried actually pricing any of this stuff yet.
That would obviously, based on my post, be incorrect. I stated, "To me, the Brultech prices seem a bit high, and their shipping charges are extremely high." If I hadn't researched the price I could not have made that statement, which I stand by. Peter_V's figures are incorrect, except that it is true that their 40 amp CT is $5.
Just minutes ago, from the Brultech store, Mono 100 Package, $176.68. And, as I said, that is just a bit high in my opinion, but not outrageous. However, unless you're walking into wherever they're at, you have to ship it. That is what the rest of my statement, "their shipping charges are extremely high," is based upon. It would cost $32.00 to ship it, bringing the price much higher than "less than $180." That's right, $32.00 to ship what I would think is a small package. Based on the shipping rates from Canada, that would mean it weighs 14 lbs. Now, even with the iron in the CTs, I doubt if the total package would weigh more than 5 lbs., but I should add that would only be a guess. Oh, and that 40 amp CT, that Peter_V was able to have shipped on eBay for $6 would cost $16 from Brultech.
The reason I asked was not to debate about the Brultech anyway, it was to find out what the price of the Arduino and the CTs were. I can code a computer, and besides, they already have code examples posted. -
Re: EcoDog vs Arduinosub3marathonman wrote: »That would obviously, based on my post, be incorrect. I stated, "To me, the Brultech prices seem a bit high, and their shipping charges are extremely high." If I hadn't researched the price I could not have made that statement, which I stand by..
My apologies then. Since you've researched this, can you please post a link to similar equipment with cheaper prices?
Best of luck with the Arduino, please keep us posted on your progress. -
I have a couple of Arduino boards, the one I'm playing with is the Max 1280.
http://www.bizoner.com/arduino-atmega1280-mega-board-with-usb-cable-and-9v-power-cable-p-180.html
It has 16 ADC inputs. Right now I've got a few CT's, when I figure it out, I'm going to use these to measure the current: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ACS750LCA-050-ND
I can get the CT's hooked to the Arduino to output raw data. I can use excel to crunch numbers, but i want to just output data sets every second, save it and not have to crunch numbers.
The Ecodog is working real well. No faults, but not worth the money...
It does allow access to your data. -
Re: EcoDog vs ArduinoI have a couple of Arduino boards, the one I'm playing with is the Max 1280.
Are you planning on sampling the current once a second, or are you going to take the hundreds(thousands?) of samples per second needed to accurately measure the current waveform and then output those hundreds of samples once per second?
You won't be able to measure current with only one sample per second, worse case example would be sampling the current every second exactly when it happens to be at the zero crossing point and you'll always see zero current.
I'm guestimating that in order to get an reasonably accurate idea of the waveform shape you'll need to sample the waveform at least 20 times per cycle, or 1200 times per second. Without knowing the exact shape of the waveform, you won't be able to calculate power factor which means you won't be able to accurately measure true power. A lot of the homemade systems I've seen just guess at the power factor and voltage which means there measurements can be off by up to 20%.
I'm not all that familiar with the capabilities of the Arduino, but doing a rough estimate exporting 1200 samples per second it's going to require something like 19,200 bps per channel. For 8 channels that's a bit over 1.5 Mbps.
Can the Arduino handle that high of an output data stream while simultaneously sampling 8 channels 1200 times per second?
FWIW I don't see any way you can output raw data once per second unless you're only looking at one channel of data. Seems to me like it's going to have to be continuously outputting data just to keep up with the sample rate. -
I'm not feeding the output straight into the A-D, it goes to a circuit that outputs a 3 second moving average current reading based on a 60hz system. As far as power factor, I'm working on that.
The Arduino board work is mainly to satisfy my curiosity and help me remember things from engineering school.
I've been monitoring my Enphase data verses utility production meter data verses, TED 1000 verses Ecodog.
Enphase to Utility production meter, Enphase reports 2.5% more power.
TED 1000 to Utility production meter reports 11% more power.
Ecodog to Utility production meter reports 2.3% more power.
So when I finish the Arduino board I'll be able to see how it reports compared my other meters. I'd like to do an instructables write up.
I'm not happy with the TED1000.
About the amount of data.... 10 bits per A-D channel and 8bits/byte
@ 1 sample/sec: 16 channels = 160 bits/sec, 20 bytes/sec
Over a day that is only 1,728,000 bytes of data. Its well within the Arduino's capability, I've gotten it to record all 16 channels 100X a second.
And I think your calculations are a bit off.
@ 1,200 sample/sec: 16 channels = 19.2K bits/sec, 24K bytes/sec -
Re: EcoDog vs ArduinoI'm not feeding the output straight into the A-D, it goes to a circuit that outputs a 3 second moving average current reading based on a 60hz system. As far as power factor, I'm working on that.
So you plan on multiplexing the data together before transmitting and then separate it out again on the other side?
At low data rates that should work fine, though you'll probably want to include some framing and sync bits/bytes, possibly include some CRC checks for data integrity. Have you ever heard of Generic Framing Procedure (GFP)? It has some rather elegant solutions to framing and errors checks that combine the two and result in very low overheard.
I didn't think the Arduino would have enough processing power left if it was running thousands of samples per second to mux the data include framing/sync/error checks, which is why I just assumed you'd use two bytes per sample on the output, you could do simple parity checks and maybe throw in an extra byte for framing/sync every time you restart the sequence.
I don't see how you can measure power factor without getting enough samples to see the actual shape of the current waveform.
I wonder if that is the problem with the TED, they might be guessing at the power factor.
FWIW I think your math is off
1,200 samples per second of 10 bits per sample = 12,000 bits per second x 16 channels = 192,000 bits per second, etc.
Though to be fair I also screwed up the math, it should have read 153.6 Kbs instead of 1.5 Mbs.
Like I said, my original statement assumed keeping each channels data in separate bytes (instead of muxing it together), so 2 bytes per sample. -
Here is a snapshot of the Ecodog pie chart...
Re: EcoDog vs ArduinoHere is a snapshot of the Ecodog pie chart...
Cool, ...what the heck do you have plugged in in the master bath that draws that much energy? -
From http://bangaloreinteractive.wordpress.com/common-arduino-commands/ it states that the maximum reading rate is about 10000 times/second (just for the reading command), which would work out to at most 625 times/second on each of the 16 channels (just for the reading command). It runs at 16MHz, so it seems more logical to just read the data and send it to a modern 3GHz processor that would then compute the values. -
We live in Seattle, so to date I have not needed to turn on the furnace but two times. So to combat moisture in the main bath we use a 1,500W heater during and after a shower. Lights are LED.
I mentioned I have a circuit that in effect creates a running average of current from the sensor. So the Arduino in effect only has to sample once a second. I haven't figured out the PF measurement yet.
To tell the truth the Ecodog has some neat features. I went climbing for two days and the wife was upset when I was able to tell that she left her office lights on all night. She then got very curious what I had done, she thought it was sneaky...and geeky.
If it weren't for the price...
Will post more screen shots. -
Some more screen shots:
My Fridge compressors cycling...
The power usage in my living room/reading room...
Solar panel production... -
Well I took a hard look at the BrulTech ECM-1240 spec. It is only a 7 channel unit, so I guess it's not fair to compare that unit to the EcoDog which is a true 16 channel unit.
BrulTech lets you "gang" CT's together on a common input. I don't see how they can compensate for different power factors from multiple CT's. So you might get a package of (2) ECM-1240's with a bunch of CT's, but then have to group them together. You still only get 14 channels with (2) ECM-1240's, verses 16 with one EcoDog.
Still undecided. -
Re: EcoDog vs ArduinoWell I took a hard look at the BrulTech ECM-1240 spec. It is only a 7 channel unit, so I guess it's not fair to compare that unit to the EcoDog which is a true 16 channel unit.
Still undecided.
Yeah, but you can buy 3 Brultech-1240s plus 34 CTs for about 1/2 the cost of ONE EcoDog
If you only want/need 14 channels (2 Brultechs) then it's only 1/3 the cost. -
Re: EcoDog vs Arduinosub3marathonman wrote: »From http://bangaloreinteractive.wordpress.com/common-arduino-commands/ it states that the maximum reading rate is about 10000 times/second (just for the reading command), which would work out to at most 625 times/second on each of the 16 channels (just for the reading command).
I hope people will forgive the faux-pas of quoting yourself, but I was hoping somebody would be able to add some additional information.
If you measure 600 times/second, that is 10 times/cycle. I'm wondering if that is enough data to get an accurate measurement of power usage. Also, is it possible to measure fewer times if it is a circuit where the power factor is an unchanging value of 1.0?
I thought I saw somewhere that there was a mathematical method to accurately determine a function with just four data points, but I can't find that now.
It would be a bit ironic if the Arduino with 16 inputs would not really be able to be used because it is too slow to measure all 16 lines accurately. -
I would think that 1/(8*fo) where fo=60 should be the min sample rate for a simple AC power factor meter, so 600 samples per second should be plenty.
- 218 Forum & Website
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
