RECALL ALERT Xantrex
                    nvyseal
                    Solar Expert Posts: 108 ✭✭✭✭
                    I got this in the mail today from SCE -
Recall date: 1-18-11
Schneider Electric Recalls Xantrex GT Series Grid Tie Solar Inverters Due to Injury Hazard
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. It is illegal to resell or attempt to resell a recalled consumer product.
Name of Product: Xantrex Grid Tie Solar Inverters
Units: About 25,000
Manufacturer: Xantrex Technology Inc. - a subsidiary of Schneider Electric, of Livermore, Calif.
Hazard: A component of the inverter can degrade, causing out gassing within the wiring compartment of the inverter. When arcing occurs, gasses could build and force the compartment cover to be blown off. If the cover is blown off with sufficient force it can injure the user or person, or cause damage to property in close proximity to the inverter.
Incidents/Injuries: Schneider Electric has received five reports of wiring compartment covers being blown off. No injuries or property damage have been reported.
Description: The recalled inverter converts solar photovoltaic voltages into utility grid voltages; allowing the owner to feed power into the electrical grid. The recalled units were manufactured between September 2005 and August 2010. These products were sold under the Xantrex, Sunpower, and General Electric brands. The brand name is printed on the front of the unit.
Affected part numbers, printed on the top of the unit, continued at CPSC website
http://www.cpsc.gov/cpscpub/prerel/prhtml11/11099.html
Units: About 25,000
            Re: RECALL ALERT Xantrex
 That would probably be the capacitor problem discussed in this thread:
 http://forum.solar-electric.com/showthread.php?t=10285
- 232 Forum & Website
