First Solar
Blackcherry04
Solar Expert Posts: 2,490 ✭✭✭
I was given this panel by a friend. It's new and never placed in service. I'd like to use it on my boat to supplement to draw on a 1000 ah ( 12V ) battery bank during the day. I have a 20 kw Generator that uses 2 gallon a hour to run. I keep the run time to 4 hrs a day or so to charge with a 150ah output xantrex sw 3000 inverter / charger.
@ $8.00 a hour to run, anything I can put back is a plus.
Model STP280-24/VB
Power (W) 280 Watts
Open Circuit Voltage (V) 44.80 Voc
Short Circuit Current (A) 8.33 Isc
Maximum Power Voltage (V) 35.20 Vmp
Maximum Power Current (A) 7.95 Imp
Dimensions (in)(LxWxD) 39" x 77" x 2"
Weight (lb) 60 lb
Connector MC-4
I need a charge controller of some kind. I'd like to know if this panel is even worth fooling with. Any advice is appreciated.
Model STP280-24/VB
Power (W) 280 Watts
Weight (lb) 60 lb
Connector MC-4
Re: First Solar
You will need an MPPT type controller.
Look at these:
http://www.solar-electric.com/motr45ampmps.html
http://www.solar-electric.com/oupofl60mpso.html
http://www.solar-electric.com/mnclassic.html
http://www.solar-electric.com/xaxwmp60amps.html
Realistically, you will need many more panels to reduce the genset usage. -
Re: First Solar
Could you tell me what the output of this panel would be for 12 v charging in ah ?? I was thinking of keeping it mobile so I could keep it oriented during the best sun hours . -
Re: First Solar
Using an MPPT charger with 0.77 derating and assuming a minimum of 4 hours of "full sun" per day (typically 2-6 hours per day depending on season):
Maximum Power Current (A) 7.95 Imp- 35.2 volts * 7.95 amps * 1/14.5 volts charging voltage * 0.77 panel+chrgr derating * 4 hours of sun = ~59 AH per day nominal
Re: First Solar
And it will not have a significant effect on a 1000 Amp hour battery bank (about 1.5% charge rate). About 15 Amps peak current. -
Re: First Solar
Thank you so much. Now I have a idea of what to expect, I was not sure in this case it would sense to use it or not. It looks like it could save a hour of running time over a 2 day weekend. There times my generator running schedule would change by just having the extra it would put in to allow me to wait on the charge and use shore power. Everything is a trade off.
Thank You again,
- 628 Discussion Forums/Café
