Looking for info on how Current Transformers work
Peter_V
Solar Expert Posts: 226 ✭✭✭
I'm thinking of building my own power monitoring setup like "The Energy Detective" using a pair of CTs around both legs of the power lines coming from the grid and from my array.
I can understand the basic idea of how a CT works (just like a regular transformer) but what I can't figure out is how to tell which direction the power is flowing, i.e. from the grid or to the grid.
Not a big deal on the output from the array since it will mostly flow in one direction, but a huge deal on the grid side of the breaker panel.
I'd appreciate any help.
Thanks, Pete.
Thanks, Pete.
Re: Looking for info on how Current Transformers work
I think, the Amperage waveform will be "In-Phase" (approx 0 Degrees Phase Shift) with the Voltage Waveform when current is flowing IN (ie: when NET BUYING Power) and then the Amperage Waveform will be approx 180 Degrees Out-of-Phase with the Voltage Waveform when current is flowing OUT (ie: when NET SELLING power).
The Waveforms you observe may be exactly the opposite relationship as stated depending upon how YOU wind your CT's - CW vs CCW.
Also, for extremely Inductive loads the voltage waveform will slightly lead the amperage waveform and for extremely Capacitive loads the amperage waveform will slighly lead the voltage waveform.
You always want a load on the secondary windings of a CT otherwise a potentially "shocking" voltage can appear.
OK ? -
also watch out for reactive power loads. Looks like some inverters like to have large reactive power loads (no real power, but CT's read them high) using CT's and meters. . . -
Re: Looking for info on how Current Transformers workI think, the Amperage waveform will be "In-Phase" (approx 0 Degrees Phase Shift) with the Voltage Waveform
Thanks, I didn't even think about comparing the current waveform to the voltage waveform, seems pretty obvious now.
I should even be able to estimate power factor by comparing the shapes and phase difference (though coding for that is going to be a pain)
Thanks again. -
Peter,
How do you plan to compute the True RMS Amps value from the almost Sine Wave shaped and potentially very noisy signal returned by the CT?
Are you using a Hardware solution, Software or a combination?
Do you think you can get +/-1% accuracy for your computed Real Power (RMS Volts x RMS Amps x Power Factor Correction) ? -
Re: Looking for info on how Current Transformers workPeter,
I'm in the early stages of researching this, but I'm planning on using a combined hardware/software solution.
Right now I'm thinking a 1000:1 CT with a precision 50ohm load, that should provide a 0-5V output for 0-100 amps. Run the output through a low pass filter to get rid of most of the noise.
I expect there will be quite a bit noise, I use a lot of X10 stuff and the power company using powerline transmissions for reporting from the meter to their office.
I was originally thinking that I might be able to figure out how to monitor the power meters communications, but I talked to a guy at the power company and he said it takes over a day for the meter to send out one packet of data. That's a bit to slow to give me the real time monitoring that I'm interested in.
Anyway run the filtered voltage into a ADC, possibly use a Arduino for this, though from what I can gather they only have 10 bit ADCs. Maybe use a PIC, have to look and see what they are capable of these days, probably don't have enough power though.
I doubt I'll get anywhere near 1% accuracy, I'd be happy with 5% but might have to settle for 10%, at least at low power loading.
The CTs I'm looking at only have 1% accuracy so it can only get worse than that.
If I use a 10 bit ADC them the precision will only be to about 12 watts. To get the precision down to 1 watt would require at least a 14 bit ADC. Not sure it's worth that much effort though.
Most of the folks that I've come across on the web that are doing similar projects just take a swag at the power factor.
However, if I can get enough samples of the current waveform then it should be possible to calculate the power factor based on it's shape and phase difference from the voltage waveform.
I have a fair amount of programming experience, but I haven't done much work with micro controllers and I might be expecting to much from them (and from me)
I'd be happy to listen to any advice or suggestions. -
I am using this for my data logging:
http://www.advantech.com/products/ADAM-5000-Series/sub_1-368QIL.aspx
Does need a computer, so using this mounted in the hallway:
http://us.shuttle.com/barebone/Models/X50v2.html -
Re: Looking for info on how Current Transformers workI am using this for my data logging:
Hmm, how much do those cost?
Thanks. -
Here is where I got them from:
http://www.bb-elec.com/product_multi_family.asp?MultiFamilyId=54
I have $ 1700 in the current setup. But using only 1/2 of the I/Os, left room for expansion.
- 628 Discussion Forums/Café
