DIY Combiner
puresolar
puresolar Registered Users Posts: 8
I am looking at building my own combiners for my panels. Before I dothough, I have a few questions.
1) What would the difference in power loss be for these two setups
Note:(1 series is 360 watts at 48 volts)
4 series of panels running 50 feet to a combiner, and then 3 feet to a charge controller
4 series of panels running 3 feet to a combiner, and then 50 feet to a charge controller
2) in the above scenario, do you believe the power loss is enough to cause concern?
3)What are the pros and cons of adding a lcd display to a combiner box to be able to show output of any combination of 4 series of panels series or all at one time?
    Re: DIY Combiner
    Can't answer, till you tell us :
    VmaxP of panels
    Amps max of panels.
    total volts & amps in each string
    Wire gauge.
  • mikeo
    mikeo Solar Expert Posts: 386 ✭✭✭
    Re: DIY Combiner
    A: 4 series of panels running 50 feet to a combiner, and then 3 feet to a charge controller
    B: 4 series of panels running 3 feet to a combiner, and then 50 feet to a charge controller
    A is the answer in most cases since each string is 1/4 the total amps and wire costs seem to go up exponentially with gauge. This is a balancing act depending on the current levels, wire gauge and distance. You can use a wire chart calculator to estimate the trade offs.
  • puresolar
    Re: DIY Combiner
    Panel specs are:
    •205 Watts
    •33.2 Voc
    •26.6 Vmp
    •8.36 Isc
    •7.71 Imp
    array info would be:
    max voc = 135.386666667V < 150.0V Vin Max
    Min Vmp = 104.661333333V < 62V Vb Max
    Max Vmp = 107.594666667V
