USB, Laptop charger
mr.radon
mr.radon Solar Expert Posts: 158 ✭✭✭✭✭
Anyone have a recommendation for a good portable (backpack) solar charger with a USB connector?
I guess it would have to be rugged, lightweight. Maybe 1-3 Watts.
I've thought of getting a pannel off e-Bay and adding a 5V regulator and USB connector.
Anyone use a product like this?
    Re: USB, Laptop charger
    You may need a large capacitor (or small battery) at the 12V side, to stableize the voltage, and use a DC-Dc convertor to get your 5V. A simple linear regualtor LM7805, will waste about 2/3 of the power as heat, and you ge1 1/3 of the power at the output. (power as in watts, not volts)
  • mikeo
    mikeo Solar Expert Posts: 386 ✭✭✭
    check out this regulator
    http://www.dimensionengineering.com/DE-SW050.htm
    I have used them in several projects powering 5 volt cameras, 5 volt weather stations from 12 volt battery but should also work with tiny 12 volt battery and small direct connect solar panel.
  • dwh
    Those fold up portable PVs are hella expensive.
    I'm seriously considering getting on of these:
    http://www.thinkgeek.com/gadgets/travelpower/e193/
    Probably heavier than I'd want to pack though (if I still packed...I don't, I'm too old and fat for that anymore).
  • James
    James Solar Expert Posts: 250 ✭✭
    MikeO,
    thanks for sharing/posting the link.
    i've got a couple little projects..looks like the units might work great!
    james
  • mr.radon
    I bought a 9v 1.5w panel. going to hook it to 6 1.2v aa batteries a Schottky diode a 7805 volt reg and a usb port.;)
  • mr.radon
    Well, I tested the design. It works real well.
    Looking for a good light weight potting material. Suggestions?
    Used the mentioned components, however, I added a "OFF" switch since the 7805 draws 8ma when not in use. Not good ofr long term sotrage.
    The 1.52W panel was able to charge the batteries from 30% charge to 80% charge in a day (November). Given the long expidition will be Africa in the summer she should be able to recharge the battery pack 100% durring the day.
