George Foreman Grill on Solar...
Photowhit
Solar Expert Posts: 6,002 ✭✭✭✭✭
I've had an abundance of electric lately, at least while the sun's shining...
So I've been playing with the 'extra' electric.
I picked up a small Foreman grill, it uses 760 watts, cooks from both sides, and has a thermostat...
It works great and has only about a 50% duty cycle!!!
Cooks a couple big burgers in 8 minutes, 3 minutes warming up and 5 minutes cooking! about the same for fish and pork, slightly longer for chicken.
Very effiecent cooking, a slight pain to clean up, cleannig around the raised grill things.
Re: George Foreman Grill on Solar...
For those days with a lot of extra power I have a one element electric countertop "range". It's ok, but I'd forgotten how long it takes to heat up electric elements and the residual heat when shut off. Spoiled by propane range...heat on, heat off at the turn of the dial.
Electric element good for warming a pot of water, soup etc, but it's the on or nothing, not variable heat type, so real cooking is out of the question. A $15 experiment.
Ralph -
Crock pot
`125-200 watts would work pretty well when the batteries are full. I could envision a way that once the crock started drawing from the batteries you could move the crock to the stove top, particularly a wood stove. Never tried it, but no reason it shouldn't work.
T -
Re: George Foreman Grill on Solar...I've had an abundance of electric lately, at least while the sun's shining...
When my FG gets crusty I use a old dish cloth or paper towels soaked in water inside until it starts to steam. The crust just peels off. -
I have a the one with removable panels. You can take them off the grill and then soak them in soapy water. Then the stuff just comes right off. Very easy to clean that way.
