Morningstar tristar 60 rts
rplarry
rplarry Solar Expert Posts: 203 ✭✭
I am installing a rts for a freind on his tristar60. The connection on the tristar is 2 phillips screw connections, but when the rts arrived it has a phone style connector with a 4 wire plug. Anyone else had this and which 2 of the 4 wires did you use for the connection?
Larry
    Re: Morningstar tristar 60 rts
    check with morningstar and check that it is for your controller as neither tristars should have that type of termination that i can see. once morningstar confirms or denies then approach who you bought it from as they may have grabbed the wrong one for your controller and should make good on it. i had this difficulty with a vendor other than our host who actually did not know there was a difference.
