Performance question?
I have installed a 5460 watt pv system with Kyocera kd-210 panels and a sma 5000 inverter. South facing with a 5 degree pitch, no shading. It was installed in Dec of 2009, the highest wattage I've seen was a few days ago it was 5110 watts on the display. Does this sound good for this time of year?
I have been very impressed with the system so far, I have had 0 problems, It has worked flawlessly since I kicked on the breaker.
Thanks,
Jamie
Thanks,
Jamie
Re: Performance question?
- 5110 watts peak/5460 watts of panels = 93.5% (output / name plate)
- 3,000 watts peak /3,500 watts of panel = 86% ratio (output / name plate)
One note, some brands/models of solar equipment (particularly solar charge controllers) tend to over estimate power produced by upwards of 5-10%. (I don't know accuracy range of SMA). So take any production numbers with a grain of salt unless independently verified or Inverter specifics meter accuracy.
In the end, keep track of kWH output (by month or year)--and watch year over year production for any dramatic fall-off in power output (my guess, any year over year numbers with less than 10% differences is normal weather variations).
- 626 Discussion Forums/Café
