Best way to equalize batteries off-grid - Cheap Generator?
cdre
cdre Solar Expert Posts: 78 ✭✭
In the past, I've used a 2 stroke 1000w generator run for 12 hours or so to equalize my 12v RV sytem with 4 12v batteries.
Shifting over to a 48v system and trying to ensure I take care of my batteries, I'm wondering what the most cost effective way to equalize is... I wonder if I can get away with the same small generator idea...
How are you guys doing it?
    BB. Super Moderators, Administrators Posts: 33,431 admin
    Re: Best way to equalize batteries off-grid - Cheap Generator?
    What is the AH rating and voltage of your battery bank?
    A good quality power factor corrected AC battery charge mated to a good quality genset of appropriate size is still not a bad way to go for charging/backup power.
    Ideally, for most generator you want to run them at a minimum of 50% load for good fuel efficiency. The Honda eu2000i can run down to 400 watts / 25% load at good fuel efficiency because of the inverter/generator (allows engine to throttle back to a lower speed when power requirements are low).
    But, this all has to match your battery bank + battery charger for optimum cost and fuel usage.
  • cdre
    I'm looking at a Northstar Trifuel 6.6kw generator for typical use (surge loads and bulk charging), but thinking a smaller gen would be better for long equalization (float) runs... Battery bank likely to be 16 T-105s in two 48v strings with an Outback FX3048T.
    I always keep a smaller generator handy as a backup anyway, but wondering if I can get away with the 1000w disposable chinese generator for a monthly battery burn. I'm not sure if it would have enough power to supply that equalizing charge.
    Your choice on the small generator... How many hours do you expect on the 1,000 watt guy vs the 3,000 hours +/- that you could get on the much more expensive (and quiet) Honda eu2000i (1,600 watt rated).
  • cdre
    I've actually had 2 of those units, and I can't complain too bad... The biggest problems I've had is carbon buildup at the exhaust (too much 2 stroke oil) and pull cord failures. Carbon bulidup occured after about 6 months of 2 hours or so daily (before I went solar). If I'm running the generator very infrequently I won't be pulling on the cord all the time (less starting wear and tear).
    While the metallurgy on those little engines isn't comparable to a honda engine, as long as you buy them knowing they are disposable, they are very handy.
