TriStar-45 Firmware update issues
Hey all,
I've got a new TriStar-45 with software version 13. Before I permanently install the system, I thought I would update the firmware to their latest load 15 as it enables some historic logging of data.
I am using their MSLoad firware utility. As I read their manual, it indicates I must first update the bootloader and then the firmware. When I start MSLoad, and select the boat load and Com Port (#1 in my case), the utility is never able to connect to the TS-45.
I have confirmed that the Com Port is correct and working -- if I use their MSView utility, it is able to connect to the TS-45. The MSLoad utility never connects to do the update. I have tried a couple of laptops, have restarted both the laptop and the TS-45 but it never works. Anyone have any tips or hints to get this to work?
    Re: TriStar-45 Firmware update issues
    Is this the PWM or the MPPT tristar ? For the MPPT version, I abandoned the modbus adapter I ordered, and programmed vis serial port, via a usb adapter on my PC.
  • TenMile
    TenMile Solar Expert Posts: 62 ✭✭
    Figured it out with the help of Morningstar support. TSM-45 must be turned OFF initially. Open the MSLoad program, Choose the appropriate file and Com Port then click Next. Then turn ON the TSM-45 while MSLoad is searching for the unit. Updates then apply. Unit must be restarted for updates to take effect.
  • System2
    System2 Posts: 6,290 admin
    I have followed the Morningstar instructions numerous times. Each attempt I get the big red X. I have asked Morningstar tech support for help. I have not yet heard from them.
