Program to produce single line diagrams?
HI
I am looking for an easy to use program that can produce single line diagrams. We need to submit these to the LDC when we put in an application to connect. It used to be that they would only need a single line drawing when we were ready to install but the process has changed and the LDC now needs a SLD at the start of the process. Our electriction would produce and submit these before but we need to do them ourselves as these applications may not turn into jobs, so we don't want our electriction wasting his time on our paperwork.
  • GreenerPowerGreenerPower Posts: 264Solar Expert ✭✭✭✭✭✭
    Re: Program to produce single line diagrams?
    Visio works for me.
    GP
  • ggunnggunn Posts: 1,973Solar Expert ✭✭✭
    Google Sketchup in Engineering space works well for that, and it's free.
  • mr.radonmr.radon Posts: 158Solar Expert ✭✭✭✭✭
    I used Power Point. Worked, took longer but worked.
    mr.radon wrote: »
    I did that a couple of times. It's like trying to change a tire with a screwdriver - the wrong tool for the job.
    It's all depend on how familiar you are with the tool. For simple one-line, even paint-brush works for me - lines, circles/ovals, rectangles, text - that's all you need to use.
    GP
  • solarixsolarix Posts: 713Solar Expert ✭✭
    I'm not sure how much I recommend it, but I use SuperCAD by Mentala.com. A schematic oriented system which makes solar drawings easily. About $250 I think.
  • nsaspooknsaspook Posts: 396Solar Expert ✭✭✭
    Dia is a "simple" Visio clone for Linux and Windows.
    http://live.gnome.org/Dia/Links
    Windows port: http://dia-installer.de/
    GP
    Nevertheless, Google Sketchup, a free program, is a much better alternative, IMO.
  • n3qikn3qik Posts: 741Solar Expert ✭✭
    Drawing from the Open Office suit.
    Here is a sample:
    Here's a sample in Google SketchUp/LayOut.
    I didn't know google sketchup did line drawings! I used this to do shading analysis, i'll have to look into that.
    I use Pro-Diagram at work, but that is overkill for what the utilities need/L&I needed for the permit.
    Power Point took me all of 30 minutes. Wish i had Visio.
  • HTG PVinPAHTG PVinPA Posts: 16Registered Users
    Smart Draw works well. Not free. They have templates and symbols. If your doing quite a few a year it will pay for the time saved. Cost is $197. You can download it for 6 days and try it out. I used it for a solar hot water install and it worked well. I plan to purchase it.
    Well, I thought I attached a pdf to my reply, but it isn't showing up. I clicked on the paperclip and it said it uploaded so I closed the window. But, don't see any attachment.
    I tried.
  • SolarDesignToolSolarDesignTool Posts: 1Registered Users
    You can generate a single-line diagram using SolarDesignTool in a few minutes. It will generate a PDF, DWG, and DXF as an 8.5 X 11 or 11 X 17.
    It supports residential size systems -- two or fewer string inverters (single or multi-MPPT), inverters with optimizers (such as SolarEdge), microinverters, and AC modules. You can't use it for commercial size systems.
    Here's a link to a page that describes the feature. http://get.solardesigntool.com/features/single-line-diagrams/
    Disclaimer: I am the founder of the company and helped develop this feature.
  • rahulio25rahulio25 Posts: 1Registered Users
    Disclaimer: I work for Aurora Solar
    If you're in the solar industry and looking to create single-line diagrams, you should check out Aurora Solar. Our tool does a lot more than just single-line diagrams and you can find a more in-depth answer on what Aurora can do here: https://www.quora.com/What-is-the-best-software-for-modelling-a-PV-system
