Solar panel positioning
How much power loss is there in positioning solar panels flat on a ribbed metal roof compared to a 25 to 30 degree angled using a racking method? I live in the DFW Texas area. Thanks Doug
Re: Solar panel positioningHow much power loss is there in positioning solar panels flat on a ribbed metal roof compared to a 25 to 30 degree angled using a racking method? I live in the DFW Texas area. Thanks Doug
metal roof = HOT.
Use the panels compensation factor to estimate the loss just from panel heating. Ref temp should be 25 degrees C
Also consider dirt buildup and cleaning if installed flat. If at an angle, rainwater will wash off. As mentioned, hot panels = reduced output. They most certainly should be raised off the roof to allow air to cool the back of the panels. An angle would help that air movement.
