Inverter selection
Hi all,
I have a question....I need to feed a 10kw,200 vac 3ɸ, 50 Hz system with solar energy as main supply, I have a kazecamome unit that supplies 198 watts...how many kazecamome units do I need and which inverter do I need....If somebody can quote I will apreciate.
Thanks.
Thanks.
Re: Inverter selection
I think you need to describe what you are looking for in a bit more detail...
Is this a Grid Tied system, Off-Grid system, with Generator or without, how many kWH per day, where is the installation (country regulations, solar isolation, etc.).
Your 198 watt units are 0.198 kW or:- 10kW / 0.198 kW = 505 units
Also, knowing the actual system voltage would be helpful. I've never heard of a 200 volt, 50Hz polyphase system, which tells me the system voltage is something else.
There are some inverters from OutBack that I =think= can be used to produce a 50Hz 110 / 190 Wye 3-phase system, but again -- actual system voltages would be useful.
