New to wind enery - please check my setup
Hi guys, I have a cabin in michigan. I only use ~$5 per month of electricity but I get charged a $25 service charge.
I figure if I can go completely independent I can save a lot of money.
I was looking online and am thinking of building my owe wind turbine using an ametek 30 or 38 motor.
These are the other parts I am thinking of buying
http://cgi.ebay.com/12v-24v-Wind-Solar-Diversion-Charge-Load-Controller-/180397981178?pt=LH_DefaultDomain_0&hash=item2a008ebdfa#ht_4794wt_1156
http://cgi.ebay.com/NEW-MOBILE-POWER-INVERTER-1200-2400-WATT-DC-AC-/330506263961?pt=LH_DefaultDomain_0&hash=item4cf3b55d99#ht_5494wt_1156
http://cgi.ebay.com/New-Trojan-T-125-Deep-Cycle-Battery-Free-Ship-HEP-/170568910465?pt=BI_Heavy_Equipment_Parts&hash=item27b6b30681#ht_7298wt_1156 x2
and a blocking diode.
All i need to power up in michigan is a very small water pump and a refrigerator continuously. When I go up there once a month the only extra thing to be powered would be 3-4 efficient 15w lights.
Would this system be self sustainable or would I kill my battery? Thanks for any insight.
I also have 80 acres so if I one wind turbine is not enough I can plant more.
Does this seem correct or should I buy a wind turbine kit? Those are running ~1000 but I heard they overexegerate their numbers.
Please check my math. Watts = Volts * Amps. So 2 (125 ah) batteries should be able to hold a charge of 3 Kw. Then factor in that a battery should never be discharged by half. So I have 1.5kw capacity? That seems like plenty overhead. I figure I am using 600-800watts a day.
One last question. Is their anything I can buy to shut down my system once the batteries are worn down past 50%? The batteries are the most expensive part of this system and if the turbine broke or their was a wind drought I don't want to kill my system.
The battery charge controller is rated 160ah. Does that mean the input from the turbine or the capacity of the batteries?
Re: New to wind enery - please check my setup
Warning--I am not a fan of small wind power--So take what I say / suggest with a grain of salt.
First, here are some good DIY forums/websites for DIY small wind:
Wind Power Links
www.otherpower.com (good forum for DIY Wind Power)
Hugh Piggott - Scoraig Wind Electric site for tons of info (from mike90045)
www.greenpowertalk.org (added from "russ"--Like here but more wind/less solar)
www.builditsolar.com
Second, wind tends to be highly variable/unpredictable--So you will probably need some sort of backup power anyway (grid, solar, genset, etc.).
Third, you need sufficient wind in your location. Trees "flagging" (bent by prevailing winds) is a good indicator. Installing on 30-60 foot minimum tower, 300-500 feet way and 30' above any obstructions. Do not mount to side or roof of dwelling.
Fourth, always plan that something may fall (blade, turbine, tower) and that it is in a location where such failures are not life threatening.
Now to your power needs--The small refrigerator is a big question... A good full size Energy Star Fridge probably starts around 1 kWH per day (365+ kWH per year). Hot weather using more power than cold. And there are chest freezer conversions which can work pretty well--down towards 250 Watt*Hours per day.
Chest freezer as a chest refrigerator
You talked about running the fridge/freezer full time, but you may only go up once a month? Typically, we recommend for part time cabins to look at RV/small home style propane powered fridge/freezers. It does not take much propane usually to keep a fridge cold for a 2-7 day out of 30 day period.
It takes a fairly good sized/complex off-grid system to keep a fridge/freezer running 24x7. Plus what happens during a week+ of bad weather / no wind. Automatic genset, food goes bad, batteries killed (as you mentioned).
There are some small fridges that are intended to operate straight from solar panels--I don't know if they solve any problems though (plus appliance "stamped solar powered" usually costs 2-4x as much.
I am going to skip the Ebay stuff at the moment. I don't know the controller and inverter brands--but they are probably not something that you would want to use for an off-grid (and reliable) system that is to power electronics and fridge compressors. The AC inverter is a MSW (modified square wave) unit and not really recommended for motors/electronic loads (although, many people are happy with their setups). A couple of things to read about inverters:
All About Inverters
The Trojan batteries are fine--Look for a good distributor that can deliver them to your door at the price you are looking for (batteries can be expensive to ship). you did see that was a 6 volt battery and you would need a pair of them for 12 volts. And that T105 are around 225 AH -- So a pair 6 volt batteries in series would be:- 2x 6 volts * 225 AH = 2,700 WH
I am avoiding going into too many numbers at this time as I don't have much to start with and can end up with a blizzard of irrelevant numbers that don't meet your needs.
If we can better understand your loads (by day, and by month/season)--I would be suggesting setting up a solar array + batteries to meet your loads ~9 months of the year, and the other 3 months of the year, your wind turbine and genset could be your backup power source...
My two cents worth. Comments?
with a small bill that says you conserve very well, but the connection to the grid can be some insurance to you for power availability. it may be better to just put a small battery backed gt system in place if you are leery of outages or just get a few pvs with small straight gt inverters mounted on them. the actual cost of solar is somewhat high to go off the grid and although it seems like a good idea to dump them that in reality it may not be a good idea. this is only my opinion on the matter and your decision is your decision and know that you have options when it comes to doing this should you want to follow through with it.
